| Home > Help Needed / General Tech Chat > car has developed problems with megajolt - no longer able to communicate via the computer - please help!! | |||||||
23rd Apr, 2013 at 04:26:47pm
hi, im having problems with my megajolt setup.
23rd Apr, 2013 at 04:39:44pm
Does the com port show up in windows device manager? On 11th Feb, 2015 robert said:
23rd Apr, 2013 at 04:54:41pm
yes, via device manager it comes up as serial port com 7, which is the one I gave it. |
23rd Apr, 2013 at 04:56:28pm
when clicked on it states that 'port working properly'
23rd Apr, 2013 at 07:06:51pm
Have changed the port no, and also done this on mj, makes no difference. |
23rd Apr, 2013 at 07:08:13pm
What error message do you have in the software?
In the 13's at last!.. Just |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
23rd Apr, 2013 at 07:41:32pm
Try going into device manager and delete com port or ports and the restart computer and see if it plug and plays the com ports again, you may then have to reassign a port for mega jolt..Alan Main Build
23rd Apr, 2013 at 09:02:55pm
When the lead is disconnected it shows error 'could not open port' as expected. When plugged in it shows error 'time out reading cylinder count'. I have deleated the us , re installed it, changed the com number but still no joy. Im really gutted about this, am wondering if its the megajolt unit itself? Please any more advice is appreciated, thanks again |
23rd Apr, 2013 at 09:11:15pm
Yes once deleated the it self installs when restarting the computer. It saves as com3: i change the settings on my to com 3, still no change. |
23rd Apr, 2013 at 09:45:49pm
Iirc. You need to make sure that the auto assigned com port in the driver matches the one in the mj software. These adapters can be a little hit and miss some times. Depending on your OS it will assign a new com port if you plug it into a differed USB port. I run a supercharger and I don't care the TB is on the wrong side.
23rd Apr, 2013 at 10:17:04pm
graham I have assigned a different com for the usb. also re matched and reassigned the com no after re installing. and also matched this on megajolt. if this is what you mean?
23rd Apr, 2013 at 11:25:42pm
Google suggests two results. It's the USB adapter or the software/ firmware version
24th Apr, 2013 at 12:19:07am
I will take a look tomorrow colin, thanks for the input.
24th Apr, 2013 at 06:11:40am
I have also had the wires pull out of the mj serial lead inside the 9pin rs232 connector. It would be worth opening it up to make sure it's all connected I run a supercharger and I don't care the TB is on the wrong side.
24th Apr, 2013 at 09:36:39am
As sprocket says that USB adapter is suspect if you didn't buy a good one, I took the advice on trigger wheels and bought the one they recommended, I know it's in there interest to sell there's but been that many people had trouble with communication between the MJ and computer, I thought pay the price and be safe.. Alan Main Build
24th Apr, 2013 at 11:40:05am
going to have another play now, see if can get anywhere...
24th Apr, 2013 at 01:22:12pm
right, have this sorted now. thanks to everyone who got back to me with advice. it turns out that the lead from the megajolt to the usb was faulty somehow. there is no obvious damage, changed it for another one and it now works. again thanks a lot for the input on this chaps, its really appreciated,
24th Apr, 2013 at 02:06:10pm
Boom! Glad it's sorted I hate these types of issues I run a supercharger and I don't care the TB is on the wrong side.
24th Apr, 2013 at 02:14:46pm
me too. if you know whats wrong then you know what has to be replaced. if not its very frustrating, especially as it worked fine not too long back.
31 Posts Member #: 9334 Member |
25th Apr, 2013 at 01:14:29pm
If you look in the about menu of the configurator it should give the firmware version of the MJ, a simple check you have comms. |
