Home > Help Needed / General Tech Chat > Post 88 LHD Brake Cross Over Bar
tmsmini
Member #: 7637
Fremont California
Has anyone removed and re-installed one of these?
I have a number of manuals, but none show how this comes apart, all they show is RHD.
The pivot hole on the clutch pedal has worn to an elongated shape. I have a replacement. I am just trying to figure out what needs to come out. It looks like the heater and may be some other items as well.
The only manual that I have not checked is the Heritage CD manual, but I do not have an older system any longer to open the files. All win & with updated Acrobat.Did anyone ever solve that?
Terry
I'd take the steering column out and the heater and the dash,
I've got a full lhd conversion if needed
tmsmini
Member #: 7637
Fremont California
I have the parts. I just don't see clearly what to start taking apart.
One person told me that both the pedal box and the components on the right side need to be removed.
On older cars it is easy, there is one nut on the pivot shaft and more modern RHD is the same way.
KLAS
Member #: 2380
Hamburg, Germany
IIRC you have to remove both, yes.
