Home > Help Needed / General Tech Chat > k100 questions
topfuel
Member #: 9934
south wales
hi guys. i've decide to go down the k head route with my mini. so far i've picked up a 1275 motor(free) and have got hold off a k100 engine. as i build 500bhp jag engines all day the build should be no problem. but the wife wont let me spend a load off money on it..something to do with hoildays,garden etc.....so i gonna have to make all the sealing plates. no real problem as i used to be a engineer before. just need some pointers.
1, what cam pulleys would i need?
2, is it better to dry deck or not?
3, which head gasket would be best?
cheers terry
once i start build i'll sort a new thread
You have to dry deck
Dry deck and run a bk450 ala jimster, his survived 250+ bhp. Also mr austins conversion kits are a very reasonable price and are uk made *smiley*
topfuel
Member #: 9934
south wales
mr austins???
Fast Carl. click the banner at the top
topfuel
Member #: 9934
south wales
dry decking it is then
as for cam pulleys. ford 1.25 one ok? as i work for fords can get these cheap.
also oil feed to head if i dry deck then i have to get oil to the head. can i come of the oil pressure sensor? or where?
cheers terry
those pulleys should be ok, worst case they will foul the bonnet, but thats pretty unlikly I think.
yeah oil feed can come form the oil pressure sensor
I can sell you everything for the cylinder head to use the zetec 1.25 pullies including the seal plate (will need slight mods for the 8v cover). You will then just have to sort out the engine seals belt tensioner jackshaft adapter and modify a zetec 1.25 sprocket (or buy it from fast carl)
topfuel
Member #: 9934
south wales
hi guys a bit of a update. got myself a lathe to turn up bits and bobs. and got the ali plate to do the sealing plates.. will post pics as soon as i have something to show ya..
cheers terry
