Home > General Chat > Exhaust wrap
mini118118
Member #: 10069
Hi just wondering how you guys feel about exhaust wrapping.. my heat sheild glows 1cm under my carb and wondering if I should wrap the manifold. But surely this means that the exhaust is only going to get hotter as it cant cool due to lack of air cooling... cheers..
Anyone one got a heat sheild that they want to flog..
Ben H
Member #: 184
Melton Mowbray, Pie Country
I would check your fueling if it is glowing? Does it do this all the time or just after an extended blast?
http://www.twin-turbo.co.uk
as ben says, also the ignition timing it may be too retarded
mini118118
Member #: 10069
You boys know your stuff.... this was after a first run after a rebuild, I had the wrong map installed on nodiz so yep the timing would have been out...
Still though what do you think on wrapping your manifold...good or bad.... or hot and bloody hot!
It keeps the heat in the manifold, so yes the manifold runs hotter, but the things around it should stay cooler. Some people have had issues with manifolds cracking or warping due to the heat, but I don't think it's to much of an issue with the standard Metro Turbo item, it's a pretty robust piece of kit. I've personally run the wrap for years with no issue.
Phil.
mini118118
Member #: 10069
Well im going to say it........ Thats a wrap then.... (sorry)
Jason G does some shiny stainless heat shields.
mini118118
Member #: 10069
Well I've Wraped my exhaust manifold now and WOW i cant beleive the difference, when you lift the bonnet now the searing heat has gone, really remarkable suff !!!!!!
james962
Member #: 3663
Banbury
Did you just wrap the manifold or downpipe as well?
welshdan
Member #: 1111
s wales
I thought about this but decided not to. Not sure whats best, i guess its swings and roundabouts. Have seen so many turbos with cracks around the wastegate hole. Also if you are keeping heat in the manifold, the turbo runs hotter, so might the combustion chambers. Alternative is that under bonnet temps soar...
supermotolee
Member #: 2153
kings langley
I think your also making the turbo more efficient keeping the heat in... Something to do with the energy not escaping through heat and light it's funnelled through the turbo hence why people ceramic coat manifolds and turbine side of the turbos too
mini118118
Member #: 10069
Wrapped the manifold from the block back to the square mount to the turbo, and then around the waste gate.. pretty straight forward... cost me £10 from ebay with 10 wire ties... got the black stuff, it looks good and you wont belive the temperature difference.. the reason I done it was because my heat sheild was naff,
supermotolee
Member #: 2153
kings langley
Do you apply it wet?
mini118118
Member #: 10069
No straight out of the pack, be a bit frugal with it wrap it nice and tight, it think it looks smart, you can almost keep your hand on the manifold after you've run the engine , its that good and its better than looking at a rusty old manifold..
APS
Member #: 10369
Pickering, North Yorkshire
It's actually better to wrap it damp, it wraps tighter too.
www.apsbikes.co.uk
