Home > For Sale > Some Bits
Ok then bits I don't need:-
Turbo Fuel Pump Setup (removed as going with MPI tank) about 6000 miles old. Low pressure filter pre-pump with tee afterwards for return and injection filter post pump. Mounted on a sheet of ally with rubber lined clamps. Also cotton reel rubber bobbins on plate to further dampen noise when mounting to car. £35 SOLD
Late carb tank with anti-syphon valve £20
Unused Red alloy rocker cover with chrome cap. trial fitted, notched for 11 stud (few marks from storage) £25 SOLD
Minitastic Fast Road Coil Spring Kit With Hi-Los
About 6000 miles old all threads a spot on as they appear to have been greased on installation. Could do with a bit of a clean though. £120 SOLD
Edited by John on 6th May, 2013.
smit360
Member #: 9845
Staffordshire
I'll take the pump setup, I shall pm you now.
998 t2 ongoing project.
Prices are plus post btw
jakejakejake1
Member #: 10010
Northants
2nd dibs on pump set up if it falls through
Rocker cover and pump setup sold.
Jake I do have another turbo pump (just the pump though) on my clubby which I should be replacing with an MPI tank later in the year if you arent in a rush?
jakejakejake1
Member #: 10010
Northants
I'm not in a great rush for it so that could be an option, just let me know closer to the date when you come to get rid of it. Thanks
m30
Member #: 10415
Hi John,
would you consider splitting the springs from the Hi Los? I would be interested in the springs
Stu
Not really as the hi-los are bespoke to the springs so a pretty useless without them.
m30
Member #: 10415
ok john i didnt know that
cheers
stu
dave_39
Member #: 9976
Ok'd on the springs.
dave_39
Member #: 9976
Dam predictive text. PM'd on the springs.
Springs sold! Just the tank remaining.
smit360
Member #: 9845
Staffordshire
Received, excellent packaging I must say!
thats john *happy*
