| Home > Help Needed / General Tech Chat > Rear brake bleeding. | |||||||
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
3rd May, 2013 at 08:12:14pm
Had anyone got any useful tips for bleeding the rear brakes on a new setup, used easybleed. Use 2 man tecnique, and used both at the same time. But can seem to get att the air out of the rear system. :/ On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
3rd May, 2013 at 08:25:22pm
Brake bias/compensator valve plumbed in correctly? On 26th Jan, 2012 Tom Fenton said:
3rd May, 2013 at 08:36:08pm
Top end of the cylinder to the front brakes, lower bigger end of the cylinder to the rears. On 17th Feb, 2011 apbellamy said:
3rd May, 2013 at 10:14:20pm
Open rear nipples before connecting easibleed to air source. Push the fluid through, close nipples, remove air source. |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
4th May, 2013 at 05:39:23am
If you have a Manuel pressure regulator open it up completly (i hace one and spend 2 hours not getting it right than turned it the other way round and finisched the job in 1minute). And open up the niple. I then use a bed pump with vacuum function to drow the oil back. Sounds stupid but works like a charm. you can do anything if you set your mind to it...
![]() 580 Posts Member #: 9580 Post Whore Surrey |
4th May, 2013 at 06:42:05am
Bleed out master first by slacking off the connection then if necessary do the same with the compensator |
4th May, 2013 at 07:59:08am
