Home > Help Needed / General Tech Chat > mpi fuel pump problem
dig-mini
Member #: 9269
Rotherham
Can anyone shed some light on this problem
2000 reg mpi won't start
the fuel pump is not running. If I put wire from the battery (live wire only direct to the fuel pump it will run) car will start
There no is power at the spade connector on the pump
Can someone tell me if the pump should run constantly or should it switch off when the pressure is reached?
When the mini is turn on there's no live at the pump is there any relays or pump pressure switch to check?
I've checked all fuse and they are OK
Is it OK to just run a new live and where is the best place to take it from?
Could do with wiring diagram if someone as one
Craig
dig-mini
Member #: 9269
Rotherham
The wire that goes to the pump
Where does it come from?
I know it goes up through the roof to the dash but then where?
Edited by dig-mini on 5th May, 2013.
Craig
dig-mini
Member #: 9269
Rotherham
nop wires go along floor then into nearside dash
can any one help
Craig
Has it tripped the cut off switch on the bulkhead under the bonnet?
dig-mini
Member #: 9269
Rotherham
where is it
Craig
dig-mini
Member #: 9269
Rotherham
how do you reset it and what does it look like
Craig
dig-mini
Member #: 9269
Rotherham
Thank mate I love ya
reset it
didn't no it had one *smiley*
Craig
watch out for pot holes *wink*
