| Home > Help Needed / General Tech Chat > Turbo manifold not lining up with head studs | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
5th May, 2013 at 05:40:56pm
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
5th May, 2013 at 05:41:58pm
Oh and that's pic is the stud at a heavy angle
5th May, 2013 at 07:11:11pm
Are you saying the manifold wont fit because that stud is bent stupid, or because the holes dont actually line up ?
5th May, 2013 at 07:19:40pm
from my experience the center branch twists and pulls away from the head (3 or 4 manifolds now!)
Yes i moved to the darkside |
5th May, 2013 at 07:21:01pm
Jesus, I can see how bent the stud is. Can you get an inlet manifold in between the exhaust flanges, if you can I'd just open out the stud holes. If not, the manifold is probably knackered :/ On 26th Jan, 2012 Tom Fenton said:
5th May, 2013 at 07:39:15pm
Lol the stud is not bent
5th May, 2013 at 07:42:34pm
Will hammer it up abit Tomo but it's abit too late now
5th May, 2013 at 07:49:18pm
Edited by WRLondon on 5th May, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
5th May, 2013 at 08:49:45pm
I would chexk the manifold face to make sure it is flat across the flanges. Then elongate/ slot the manifold if required |
5th May, 2013 at 09:51:48pm
It is flat
11th May, 2013 at 11:56:45am
Try another manifold, that far out your on a hiding to nothing. You may get it on but then you have shrouded the port, and i don't think there is a lot of meat on these to grind out that much material. Own the day
11th May, 2013 at 05:00:09pm
could the studs on the head be out? |
12th May, 2013 at 07:49:27am
The branch of the manifold looks bent to me. So even if u did drill it, it probibly wouldent bolt up square!
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
