Home > For Sale > Selling complete project! 1293cc Turbo, straight-cut, Benross Head, Avonbar PH2, Megajolt, Shell etc.
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Hi guys,
I haven't posted in a good while so apologies for that, having not touched or made any progress with my mini in a good while. I really wanted to finish it but just lost interest and have now come to the point where I dont have the time, money or space to finish it, so im selling up!!
I have a complete 1293cc rebuilt engine with upgrades, built to last at 180bhp. The engine has been in the car and has run but not been run-in so it is proven. The engine was taken out due to some adjustment being needed on the crank endfloat/thrust washers and that is completed, just the engine was never put back in and the car finished off! Shame really.
Anyway - i have a comprehensive build thread on this forum, so any work done and parts fitted has been documented in here. Unfortunately I never bothered keeping receipts for the parts I bought but luckily took pics of most things in the build thread which can be found here -
http://www.turbominis.co.uk/forums/index.p...tid=159959&fr=0
So first up for sale is the engine, all work was carried out by myself, built properly and within tolerances etc with good attention to detail. All parts are brand new and have only been used 'running' for all of 5 mins. Brand new gaskets etc, Here's the spec
1293cc bored Metro Turbo block, decked, cleaned and painted etc, new core-plugs
Benross completely worked cylinder head, majorly ported, hot-spots removed etc (cost £700)
HIF44 turbo carb with brand new rebuild
T3 turbocharger - no play
Benross port-matched exhaust manifold
Benross ported turbo elbow
Avonbar actuator
Avonbar PH2 turbo camshaft with upgraded tappets
MED Vernier duplex cam gear
MED cast 1293cc pistons and rings
MED main, thrust and rod bearings
Center main strap
MED high capacity oil pump
MED Ultralite flywheel
MED Ultralite backplate
MED uprated clutch cover straps and bolts
Grey rated Clutch cover
AP Race friction/clutch plate
Minispares straight cut drop gears
Minispares straight cut - close ratio gearset
Minispares cross-pin molybdenum differential
Center oil pickup
Complete gearbox rebuild with new bearings and parts, casing acid dipped etc.
Nic Rizzardini plenum
Drilled thermostat
Trigger wheel and sensor bracket for Megajolt ignition
A few choice pics of the parts:
Engine has been sat in dry garage for a while, turns over fine! CURRENT PICS:
Video of engine running:
http://www.facebook.com/photo.php?v=843462...063894884961242
£SOLD
Next up is Megajolt setup, with ford EDIS gear, coilpack, sensor etc £SOLD
Large intercooler core with hoses £40:
Metro radiator with electric fan, piping and water temp sender joiner £60:
Both were going to fit sweet under my clubman flip-front:
13x7 Weller wheels, refurbished satin black and green pinstripe. Currently have tyres fitted but theyre shagged, wheels still mint - £200
Really nice Fletcher side exit stainless exhaust (mint) and manfilfow turbo downpipe, £130:
G - reg mini mayfair shell and logbook. Pretty clean and solid, few little rusty bits on a-panels and sills but mostly very solid. Has turbo box welded in, 1 piece fiberglass flipfront with crystal headlights, carbon fibre miglia arches, stripped interior, sound deadening removed, mountney steering wheel. No seats or dashboard or interior parts, loom needs some work and tidying but is mostly all there. Been sat a while so the balljoints and brakes are all crusty.
£850 with wheels £650 without.
Excuse the bike parts!!
Also have a clean cobra Imola fixed back bucket seat and sidemounts £170 no pics yet.
So roughly all parts up for grabs add up to around £3000, which is what the engine cost me to build alone. Excluding megajolt, wheels and shell etc. Prices are negotiable but no low-balling or time wasting please otherwise i'll just keep the parts and finish the car!!
Any more pictures needed or any more info required just ask! PM me on here or email richhudsonofc AT gmail.com
Car is located in the Portsmouth area, Hampshire.
Thanks very much
Rich
Edited by richminiturbo. on 13th May, 2013.
Il have the MJ setup mate
APS
Member #: 10369
Pickering, North Yorkshire
I'll have the mega jolt stuff.
Pm on its way.
www.apsbikes.co.uk
APS
Member #: 10369
Ah well
www.apsbikes.co.uk
adrian
Member #: 2726
wakefield
I'll take the intercooler bud. :)
Pm me you're PayPal mate
Dark Angel
Member #: 8965
MIldenhall, Suffolk
Second dibs on the inter cooler.
thejefinabox
Member #: 9597
I'm sure I've missed it twice over but if for any reason it doesn't sell I'd take the mega jolt stuff
jamiestevenbell
Member #: 9941
Derby
What size is the exhaust and link pipe bore?
Mat
Member #: 9939
Sussex England
Pm'd for shell
On 17th May, 2013 Rick.SPI said:
Big money if your prepared to do it outdoors in the field.
dev 11
Member #: 9393
stoke on trent
id take the head if you split??
richminiturbo.
Member #: 719
All PM's replied to.
Exhaust size is 3"
Engine isnt being split, unless absolutely necessary. Would rather sell as a whole
Rich
All paid mate
richminiturbo.
Member #: 719
Thanks mate, PM me your details please!!
Megajolt and EDIS gear sold!
Bargain that mate. I'd have been tempted by it a couple of months ago before I started building my own *smiley*
richminiturbo.
Member #: 719
Cheers John! You mean the engine is a bargain?
I depressingly added it up and the engine alone cost me 3k to build, i know you never get what you paid for back when selling things, but its hard letting it go at £2000, purely because all the parts are still like new!
Saying that i've been a bit of a wally pricing the shell and V5, i've changed the asking price to £650 as the shell is very solid and there's some shitters being sold for similar price! Dont want to stitch myself over otherwise id just aswell keep all the parts!
FYI to any one else interested in parts, i've priced everything at what I think are fair prices and in some ways pretty good deals! So the prices are pretty much fixed to be honest.
Thanks
Edited by richminiturbo. on 7th May, 2013.
Yep engine is a bargain IMO
Chris-G
Member #: 10229
Stroud
You have PM
richminiturbo.
Member #: 719
So do you Chris!!
UPDATE:
Shell and V5 have been sold
Clive1330
Member #: 10230
I maybe interested in the engine. Just need to see if I can find the funds without selling my 59 mini
richminiturbo.
Member #: 719
Deposit taken on engine!
kenny2
Member #: 5362
wexford in ireland
Wheels and ic still here?
