Home > Beginners Tech > ENGINE HELP
MattyC113
Member #: 10248
Hertfordshire
hi everyone need some help with my 998
have an clutch plate puller that i was told would do the job but i cant get th puller to line up with the studs to get my clutch plate off (its a pre verto one)
can anyone help
thanks
Matt
A photo of the puller will help. There's three threaded holes in the flywheel and there should be three slots on the puller into which the bolts go, and the main threaded hole in the middle to which the business end goes onto. I'm just about to do this very job myself in a couple of minutes!
the pre verto is a different thread on the puller bolts iirc but mine does both so i assume yours would
Pre verto is the fine threaded bolt. Just pulled that flywheel off.
MattyC113
Member #: 10248
Hertfordshire
Thanks guys I think I might need to make a trip to minispares an get a puller as this one is definatly not doing the job as the holes on the triangle bit (hopefully you know what I mean) is about half inch out so that the threaded bolt bits won't go into the triangle thing so a trip to mini spares may be in order
The minispares puller is a good bit of kit,the one Halfords sell is made from cheese in comparison and have had bolts pull through one before :/
MattyC113
Member #: 10248
Hertfordshire
I don't live far from mini spares so il drop in one afternoon
