Home > Help Needed / General Tech Chat > Down on power with knocking noise
On way back from Newquay and the car suddenly became sluggish and stopped boosting. Then a nasty knocking noise started from the engine. Currently stuck trying to get passed Stonehenge to get to the service station to call the AA *angry* i am thinking possibly head gasket, any ideas?
whats the boost gauge doing? flickering at all?
also, pull the plug that wasnt connected in your other post... it may have got a bit fuely and decided to give up the ghost.
Yes its still moving but the engine is very down on power, almost like its running on 3 cylinders, we are sat in the services now.
I don't have a plug socket with me.
What's oil pressure like?
It's been sat on 70psi all the way then it dropped to 50psi when pulling away in traffic.
It looks like the head gasket has gone, just done a compression test and there was none in 3 and 4.
arse.
Fingers crossed its just a head gasket, that would be a result, considering the other alternatives! *oh well*
I know mate, as it was driving nice and strong, I think the best it ever has. We were cruising at 70 + all the way. Then it just went funny.
Edited by madmk1 on 6th May, 2013.
dev 11
Member #: 9393
stoke on trent
nothing do with the oil you dropped on the way there mate?
oli79
Member #: 8480
double arse
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
I hope not dev. Think I will pull the head tomorrow and have a look. Well my left is here,, let's see how this goes.
Could it be a gasket from the dodgy batch?
What is it with headgaskets at the moment, my mate turned up at my house the other day with a failed headgasket. Lucky I had an old spare on the shelf.
When I build the twink I'm fitting an sc gasket, that's that decided.
were slarks quite conservative with the timing simon ?
I got it if from mini speed about last year I think. no robert the map was not played with. I will give you a call tomorrow Rorbert for a chat.
I was thinking the same..
