| Home > Help Needed / General Tech Chat > Engine steady's - which ones can I use? | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
6th May, 2013 at 09:29:46pm
Have a huge great brake servo which I guess you could squeeze one next to
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
432 Posts Member #: 7856 Senior Member Essex |
6th May, 2013 at 09:41:09pm
You can fit a pair on the rear of the transmission which mount to the subframe, I think Minispares sell the kits if I remember correctly |
6th May, 2013 at 09:42:18pm
for years i have run a solid top steady ( brake master - block) and minispares lower gearbox steadys x2 1 either side
Edited by Brett on 6th May, 2013. Yes i moved to the darkside |
6th May, 2013 at 10:11:40pm
Hmm being in the car already I'm not sure I can machine a second one on haha!
6th May, 2013 at 10:28:18pm
i run a standard top/ bottom steady in original positions with solid bushes. seems to work well. i do have the minispares rear gearbox steadies but haven't ever got around to fitting them. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
8th May, 2013 at 08:47:08pm
MSSK and MSSK001 from MiniSpares - superb, tidy, and easy to live with. Metric is for people who can't do fractions. |
8th May, 2013 at 09:01:06pm
as above, mssk and mssk001, plus the avonbar steady that goes from the bulkhead to the waterpump (check it will fit with your bulkhead box though)
i think crushing the actuator on a very hard 25psi launch didnt help the situation
first time i got good grip all day too lol
