| Home > Help Needed / General Tech Chat > is this right? | |||||||
![]() 323 Posts Member #: 41 Senior Member |
28th Dec, 2003 at 03:03:19pm
still cant get the car to fire up, just thought id post a few pictures to show how its set up, and if anyone can see anything obvious that would prevent it from starting A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
28th Dec, 2003 at 03:35:38pm
Correct me if im wrong but thats not a turbo carb is it? Edited by iain on 28th Dec, 2003. |
28th Dec, 2003 at 04:20:19pm
it looks to me that the top of the carb is a turbo, as it has the clamp on the dashpot, but there does not look like enough pipes on the main carb body to me On 15th May, 2009 TurboDave said:
28th Dec, 2003 at 05:57:57pm
as far as im aware it is a turbo carb, at least its the carb that came with the engine, it also has that valve on the throttle buttefly which i thought turbos only had? the engine seems to be from a mk1 turbo as it has a slightly different ignition module to the later ones. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
28th Dec, 2003 at 07:55:16pm
I got a turbo carb around and it has the throtle control on the left side of the carbs as ur looking from the front of the car, but i thought that was the only diffrence. |
28th Dec, 2003 at 09:29:24pm
im pretty sure it is a turbo carb, maybe dave might know if there is a gauranteed way of telling if its turbo or not. i suppose its difficult trying to describe an engine that wont spark as it could be down to a few things, im sure the timimg of the dizzy is right, the plugs spark, and there is fuel in the float chamber and i have checked all of the things that dave has said to above... A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
28th Dec, 2003 at 11:55:05pm
Well it has the correct carb spacer for a turbo, and the right dashpot, the only sure check is if it has the square section o-ring (or rather the groove) between the dashpot and body.
29th Dec, 2003 at 07:52:12am
The engine will not know where the carb came from. It should start and idle with HS2 !
29th Dec, 2003 at 10:43:39am
dave, i will try blocking the blue pipe im a minute, post up what happens, i live in plymouth, devon. (i think this is where we need our locations under our names as suggested, admin! A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
