Home > General Chat > how much fuel for avon?
Carl
Member #: 95
liverpool-on-sea
any one have a rough idea on how much fuel ill need for my mini for avon?
im going for the weekend and will probably be doing as many runs on both days as possible, my engines roughly standard so any one got any ideas how nuch to bring? minis getting trailered.
only asking coz i need to go and buy some jerry cans*smiley*
Nicky
Member #: 333
Tadley, Hampshire
Where do you live?
Dangerous
Member #: 417
The strip is 1/4 mile long,so if you do 10 runs that will be 4 miles
Hope this helps
Edited by Dangerous on 28th Jun, 2005.
1/4 (0.25) *10 = 2.5
Assuming you drive along thr return road, I'll say it's approx 1/4 mile back. hence 5 miles = 10 runs.
Then you need to add up that you probably do 1/10th of a mile in a burnout on each run - so that's another 1 mile.
Then you need to add up going into stratford village when you run out of money, especially if the car-boot sale is on next door on the sunday - so that's about 9 miles return at a guess.
etc, etc, etc...
*tongue*
AllanMcD
Member #: 414
Dalbeattie Scotland
That will be around 2 liters then.
or probably a bit more to be safe.
http://www.rabdunn.co.uk/
Dangerous
Member #: 417
If you take it easy,light on the thottle with no hard accelertion more mpg will be achieved
Dangerous
Member #: 417
What about braking distance
Jase
Member #: 349
Lutterworth
Shell is only a couple of miles down the road so regular fillups are no probs.
I always use more fuel in the genorator than my mini, I think it was something todo with jons mrs always wanting to dry her hair!
Indeed, but braking is usually on the over-run, so not muche fuel used... As commented though - the petrol station in the village sells Optimax! Very usefull.
evolotion
Member #: 83
Glasgow, Scotland
i go through 4ish galons in 20 runs at my local strip, that was with a stage one 1275. :)
with the valver, i went through about the same in 10 runs, thats running just over 100 brake..
Denis O'Brien.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Fear not.. there is a garage just up the road that sells real leaded 4 star.
