Home > Help Needed / General Tech Chat > kad again
t3gav
Member #: 229
Gavin@minispares.com
kent
sorry i knew this a while back but forgot, after seeing the black miglia on 10" minilites in miniworld i want the same wheels, am i right in thinking that the largest size they come in is 10x6 as they seem to fill the arches maybe they have spacers on? also will kad 7.9" discs/callipers fit under these and do i need to change my hub flange (they were the turbo 4 pot type). also i know kad do 7.75" discs for classic wheels but surely the calliper size must change as this is the only thing that will rub unless they do different flanges, sorry to waffle hope that makes sense
t3gav
Member #: 229
kent
sorry i know that sounds confusing but basically is anyone using 10" minilites with 7.9" discs?
turbo hogster
Member #: 178
stowmaket suffolk
they should do gav thats why they are 7.9 inches so the calpiers just fit under the tens, but there isnt much room to spare. so when you get the wheels balenced make sure they fit the weights in the middle of the wheel if not the capipers will rip the stuck on weights of on the inside on the wheel.
hope this helps
t3gav
Member #: 229
kent
cheers mate just rang kad and they confirmed this as long as i get 6*10's which i will anyway not quite sure why though, they also do a 7.75 inch disc for proper retro wheels
