Home > Help Needed / General Tech Chat > O/T Fiat Abarth Door Trim
As the exterior door handle of the wife's Abarth came off in my hands this morning, I need to put a new on on. Common problem it seems.
The only door panel I've ever removed is a mini.
I've found all the screws that hold it on, just need advice on useful tools to get the clip things out.
These sort of things...
http://www.amazon.co.uk/Door-car-trim-upho...r/dp/B001J52274
http://www.halfords.com/webapp/wcs/stores/...tegoryId_255216
The amazon one wil. The halfords one we hardly use , its only usefull for the horse shoe style clip on the back of a old ford window winder.
To be honest if you can get say a plastic wedge inder the bottom corner of the panel it should then be enough to get your fingers under to give a swift pull. The top part of the panel is usualy hooked over the inner weather strip.
Sorry carnt help more. Only had a handfull of 500's in and non of them with the door panel off lol
rick
My nieces 500 did the same thing.
I've got a load of these which do the job well enough:
http://www.ebay.co.uk/itm/300875985329
The lazy man in me quite likes the look of these though:
http://www.ebay.co.uk/itm/390586280806
Cheers guys.
I also have a new boot handle to fit and a new lever on the seat to tip it forward.
We've had the car from new in 2009 and only done 25k in it, total crap.
Edited by wil_h on 12th May, 2013.
Our gerts mate has a 12 plate twin air. It's broken down on her 5 times! Coil packs, clutch packed in, wouldn't start etc. She's been trying to make fiat take the car back but they aren't Having it.
FIAT = Fix It Again Tomorrow
dev 11
Member #: 9393
stoke on trent
Iv got both of those and the metal trim clip tool, all cheap off ebay but so usefull! The pliers are good for prising say stick on number plates etc
