Home > Help Needed / General Tech Chat > Couple of quick carb questions...
APS
Member #: 10369
Pickering, North Yorkshire
Referring to these pics....
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
Does the throttle lean off pipe need to be of a particular tyre, or can say a 5mm silicon tube be used?
Also, the same question for the blanked off anti run on.
Cheers guys. :)
www.apsbikes.co.uk
5mm tubing will be fine. ID is not critical to its function.
APS
Member #: 10369
Lovely thanks Phil. I figured that would be the case, but i figured I'd make certain :)
Another quick question if I may...
On the throttle cable side, just above the idle screw area... In the second pic on that link it is at the 5 o'clock from the dash pot.....
Can that screw be bought separately? I think mine has snapped, as the head moves, but the bottom doesn't :(
www.apsbikes.co.uk
Ben H
Member #: 184
Melton Mowbray, Pie Country
I would not use the small bore silicon pipe, it is crap. If the lean off pipe splits the car will not run right and the small silicon tubes have a habit of splitting and not looking like they are split.
Cheers guys. :)
http://www.twin-turbo.co.uk
APS
Member #: 10369
Cool, advice heeded. Perhaps I'll stick to the short bit of fuel pipe that's on it.
So, has anyone else had their idle screw bugger up? I'm a little unsure if it can be replaced, or even how to get the bastard out at the minute.
www.apsbikes.co.uk
