| Home > Help Needed / General Tech Chat > Paint stripper?? | |||||||
![]() 308 Posts Member #: 10369 Senior Member Pickering, North Yorkshire |
13th May, 2013 at 06:54:37pm
Has anyone come across anything a bit more hardcore?
www.apsbikes.co.uk
13th May, 2013 at 07:01:58pm
POR15 POR-Strip Paint Remover is decent but toxic stuff. |
13th May, 2013 at 07:06:22pm
bead/grit blasting gun maybe? On 26th Jan, 2012 Tom Fenton said:
13th May, 2013 at 07:18:02pm
http://www.paint-strip.co.uk/
13th May, 2013 at 08:05:10pm
I found tesco own brand paint stripped was far stronger than nitromors when I did parts of my shell.
432 Posts Member #: 7856 Senior Member Essex |
13th May, 2013 at 08:21:09pm
The new nitromors stuff isn't as good as it used to be. They removed the dichloromethane from it as it is banned under the EU, if you can find some "old" stuff it should work, but it is worth saying that it must be banned for a reason so use it carefully |
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
13th May, 2013 at 08:38:57pm
there is non toxic stuff that does work, but it is not cheap.
Edited by Sir Yun on 13th May, 2013. That sir, is not rust, it is the progressive mass reduction system
13th May, 2013 at 09:28:09pm
I can't really blast it as its assembled, just missing the head, timing cover, bell housing.
www.apsbikes.co.uk
14th May, 2013 at 02:10:14am
POR still took 2 coats but its the best stuff I've used. |
14th May, 2013 at 09:28:43am
How long are you leaving it on for?
In the 13's at last!.. Just |
14th May, 2013 at 09:45:03am
I've only done it with nitroshit so far, and I left it on 40mins as per the instructions.
www.apsbikes.co.uk
14th May, 2013 at 11:27:29am
I've had issues getting the original engine lacquer off in the past; it was as if it was part of the block! |
14th May, 2013 at 12:05:43pm
Unfortunately there isn't much out there that works really well because of the new laws.
![]() 178 Posts Member #: 10196 Advanced Member |
14th May, 2013 at 12:22:12pm
14th May, 2013 at 02:06:32pm
I think however, I wouldn't really want to do that with an engine that's built?
www.apsbikes.co.uk
14th May, 2013 at 03:54:19pm
Sorry i should have said use the pressure washer to get the nitromors off. Usually works well for me. Edited by jonny f on 14th May, 2013. |
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
14th May, 2013 at 04:33:53pm
Wire wheel in a drill or grinder? |
14th May, 2013 at 07:05:20pm
I'd lash a load on and leave it for much longer.
14th May, 2013 at 09:05:17pm
as above,
14th May, 2013 at 10:02:23pm
Thanks boys. Well, would you Adam and Eve it Dev, that's just what I've been doing. Took bleeding ages, but I've got the front down to nearly bare now.
www.apsbikes.co.uk
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
16th May, 2013 at 06:54:17am
Best one I've found is by a company called langlow, it's called strip away pro. It's like the nitromors of old! |
