Home > Help Needed / General Tech Chat > carb vent pipe leaking fuel
adam1330
Member #: 238
essex
what would cause the vent pipe to leak fuel?
its currently blocked off but fuel is dripping from the joint.
Float bowl needle jammed open or fuel pressure too high
adam1330
Member #: 238
essex
must be the float bowl sticking then as ive not touched the fuel pressure.
the fact that i recently had an engine bay fire probably hasnt helped and has probably affected the internals of the carb.
