| Home > Help Needed / General Tech Chat > what rs turbo actuator is best for the t3 | |||||||
![]() 517 Posts Member #: 9931 Post Whore brighton |
14th May, 2013 at 07:44:17pm
as above looking on ebay there are the various 2wd , 4 wd ,-31, -34- as i need to have one for about 15 psi daily and can be bled out thanks charlie |
14th May, 2013 at 08:04:37pm
I run a 31. With hardly any preload it ran at 6 psi, most i can get it to hold os 15 ish psi.. |
14th May, 2013 at 08:05:27pm
and are they a straight swap |
14th May, 2013 at 08:20:20pm
Look for a second hand rebuildable one, forge sell springs to suit and so do ebay On 26th Jan, 2012 Tom Fenton said:
14th May, 2013 at 09:21:38pm
The standard ones are not servicable. The -31 is supposed to have a more progressive spring, from what iv read on the ford sites. It depends on what its off if ots a straight swap, sometimes you need to use the metro arm etc, the actuator itself will bolt straight on. Hows the rebuilt t3 going? |
14th May, 2013 at 09:55:09pm
Hi dan yeah its Been good ive done 4000 miles on the turbo seems ok I have a feeling the shaft it self is worn as when its under serious load it pumps out some smoke but am just going to use it for a while :) hows yours? |
14th May, 2013 at 09:55:12pm
14th May, 2013 at 10:50:57pm
Seems ok, not really seen any boost yet as the engine leans out massively. Spec has changed quite a bit from last engine, fitted my new needle today, taking it to the rollers next week so we will see! |
15th May, 2013 at 06:52:29am
Oh sweet let me know how it goes |
