Home > For Sale > SMMC 1380 engine (brand new)
wolfy
Member #: 8939
Banbury, Oxfordshire
The engine from the mini needs to go ASAP, the rest of the shell has gone, so will now be living outside until someone buys it! It was built, never run, still in the condition it came from the engine builders. It cost just shy of £5000 to build!
Spec:-
73.5mm bore, omega pistons
Lightened & balanced A+ conrods
Wedged, cross-drilled & balanced crankshaft
Pre-verto lightened & balanced flywheel
Grey diaphragm & rally bonded clutch plate
Piper 649+ camshaft
Lightened cam followers
MED 'S' management damper kit
MED alloy duplex vernier kit
MED billet oil filter head
Cooper s pressed rockers
SMMC breather system
SMMC offset cylinder head, 11 stud
Rim flow 37mm inlet valves, 31mm offset exhaust valves
240Ib valve springs, 3 angle valve seats
Bronze valve guides
Tran-x SCCR gear set
Mini sport centre oil pick up pipe
Minispares 4 pin differential
Straight cut drop gears 1:1
3.7 CWP
Collection from banbury, Oxfordshire (OX16)
Offers will be listened too, £3500/offers
Get it inside somewhere mate it will be worth feck all if the weather gets in there
WRLondon
Member #: 8636
Surrey
Jeezz tarpaulin at least fella!
Looks lovely
Sure it would sell pretty quick if you where to split it and may get a better price
I'm interested :)
Reading up on RTS Clutches
1380rich
Member #: 9766
Warwickshire
You spoke to Ben about this? I told him at riv run ... Seemed real I retested as he's getting them to build a 1380
Avon 2010 class c 3rd
wolfy
Member #: 8939
Tarpaulin etc is fitted.
Rich, Ben who? Give him my phone number and get him to drop me a text or sumin
1380rich
Member #: 9766
Warwickshire
Sean's mate, was at riv run
wolfy
Member #: 8939
Any offers around £2750? Really need this gone...
wolfy
Member #: 8939
Had an offer of £2000, cash tomorrow. Someone offer me more & take it away!
