Home > General Chat > Custom steel cutting
MarkGTT
Member #: 1194
Shropshire.
Hi, does anyone know of a web site you can design and request custom steel cutouts? I need a mounting plate for an internal pedal box and don't really want to do it by hand.
Thanks Mark
WRLondon
Member #: 8636
Surrey
I'd say your best bet would be to design it yourself and go to a local machining shop
Photoshop, CAD or just ms paint with dimensions haha!
The option you've chosen may be considerably more expensive!
Reading up on RTS Clutches
MarkGTT
Member #: 1194
Shropshire.
Yeah, really needs to be laser or water cut though to get a decent finish. I'm happy to design it, was really after a uk version of something like this http://www.emachineshop.com/
Use Emachineshop software to design your part and then export the format into DXF or IGS or STL files that any decent machinist shoud be able to make your part from. Emachineshop software wis easy enough to learn quickly and you can and do get good results.
The DXF in 2D for a simple part cut from plate should be all that is needed in reality, you just then tell them how thick you want it cut.
Lazer cutting has a rougher edge finish than water jet, and water jet is preffered over lazer when cutting aluminium or copper.
If you can do a decent drawing, contact Ralph at www.componentengineering.co.uk
He can waterjet or laser as required and is always very helpful. He'll just post it off when done.
Edited by stevieturbo on 18th May, 2013.
MarkGTT
Member #: 1194
Shropshire.
Ideal, cheers lads.
Or go onto eBay and contact one of the companies doing custom exhaust flanges. *wink*
MarkGTT
Member #: 1194
Shropshire.
Also worth a go, cheers Matty.
Jason G can do stuff like that too.
kcchan
Member #: 8853
As can Jon Betts from minimag. He's on Facebook if you need a link
edit: https://www.facebook.com/JBFabrication?fref=ts
Edited by kcchan on 19th May, 2013.
Tomm
Member #: 1432
Kent
Are you after something to be laser cut?
I have the facilities to have things cut and folded depending on what it is you are after.
Drop me a PM if you fancy
MarkGTT
Member #: 1194
Shropshire.
Thanks again
Tom will drop you a pm :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Just noticed this post! Yep, can get laser cutting done. Generally materials up to 6mm. We do thicker, but generally means a lot of waiting.
On 19th Jan, 2010 wil_h said:
MarkGTT
Member #: 1194
Shropshire.
Cheers Jason you have a pm :)
For the record Tomm was very helpful, I just couldn't use the materials he could cut. But a top bloke!
Edited by MarkGTT on 22nd May, 2013.
MarkGTT
Member #: 1194
Shropshire.
Dp.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
No probs MarkGTT. Can do Aluminium (5251 grade), Stainless Steel (304 grade) and mild steel. Other grades I have to see what's about.
Custard
Member #: 8215
Rayleigh
What laser do you have Jason G ?
Dave the Cake
t@z
Member #: 452
Chester, UK
i got my stuff cut at http://www.controlwaterjet.co.uk/
helpful especially as my order was on the small side to there normal orders i guess.
www.twitter.com/lilpinkiy
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Prima, not sure what model. If I had to choose....Bystronic. Mind my friends place use Trumpf which looks okay.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Sorry Tomm, didn't see your post there. What kind of work do you do? Anything I'm unable to do I could pass to you.
