| Home > Help Needed / General Tech Chat > Pitting on Straight cut gearset | |||||||
18th May, 2013 at 11:36:16pm
Hello. I have just split the box from my engine and found that the majority of my gears are pitted. The box was bought with 300 miles use from a friend and it is a minisport gearset. Ive since done an extra 6,000 miles. What would have caused this and is it useable? As I want to sell it and replace with a minispares gearset?
Edited by Johnny on 18th May, 2013. |
1170 Posts Member #: 8636 Post Whore Surrey |
19th May, 2013 at 02:01:56am
Looks to me like it has been ragged!
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
19th May, 2013 at 04:37:18am
I dont know details of minisport kit but if its like all the ther stuff i have had over the years the quality is probably not as high as it should be Yes i moved to the darkside |
19th May, 2013 at 06:19:45am
Thanks for the replies. It's had a beating! Haha. 180 Nanas. And a few track days/drag races.
19th May, 2013 at 06:38:36am
The Minisport gearset in mine lasted 3000 miles at 170nanas an a further 2000 at around 200 before loosing a tooth off third on the laygear.
In the 13's at last!.. Just |
19th May, 2013 at 07:53:43am
Hmm so I'm lucky then haha. I'll whack it on eBay sometime soon. Thanks for the replies. |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
19th May, 2013 at 11:48:11am
Just jump in question. . Is it necessary to have straight cuts gears with around 140 bananas if tje primary gears are straight? you can do anything if you set your mind to it...
19th May, 2013 at 12:14:55pm
you'll just about get away with 140, On 28th Aug, 2011 Kean said:
19th May, 2013 at 04:11:41pm
Get a minispares clubman set Johnny, dump the lay gear its worn!!!
19th May, 2013 at 05:11:19pm
When you put it on ebay make sure you put in the heading Turbo/mk1/1275/1380/space ship/works race/kad/med/f1
19th May, 2013 at 05:31:35pm
LOL On 28th Aug, 2011 Kean said:
19th May, 2013 at 07:00:47pm
I had this on jkd drops before, nothing lasts forever |
19th May, 2013 at 07:19:47pm
not even cold november rain... On 28th Aug, 2011 Kean said:
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
19th May, 2013 at 07:42:06pm
Hahahahaha
On 19th May, 2013 Joe C said:
not even cold november rain... Edited by oli79 on 19th May, 2013. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
19th May, 2013 at 08:05:25pm
Hahahahaha brilliant!
19th May, 2013 at 08:09:23pm
Considering that is first gear and you are very unlikely to be putting all 180hp through it, with ~7k miles on it shows the quality On 26th Oct, 2004 TurboDave16v said:
19th May, 2013 at 08:10:30pm
On 19th May, 2013 MarkGTT said:
I had this on jkd drops before, nothing lasts forever That is true, but you would hope it would last a bit longer than it has. On 26th Oct, 2004 TurboDave16v said:
19th May, 2013 at 10:11:33pm
4th is worse than 1st |
19th May, 2013 at 10:46:04pm
There is no fourth 'gear' as such.
19th May, 2013 at 11:00:44pm
the one closest to my drop gear? |
