| Home > Help Needed / General Tech Chat > gearbox rebuild | |||||||
61 Posts Member #: 9748 Advanced Member Bedfordshire |
21st May, 2013 at 06:03:04pm
hello everyone,
21st May, 2013 at 06:11:32pm
If you mean the big single and double roller bearings, then yes. They take a lot of load. On 11th Feb, 2015 robert said:
21st May, 2013 at 06:22:41pm
All bearings are a good idea IMO I run a supercharger and I don't care the TB is on the wrong side.
21st May, 2013 at 06:43:07pm
well i thought i had the name right for the 1st and 3rd motion ones (big ones that hold the maingear shaft in)
21st May, 2013 at 07:47:58pm
Yep do all of them, also check the layshaft for wear, where the needle roller bearings run on it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st May, 2013 at 08:30:57pm
will do tbh everything seems fairly loose as a goose in there to me, ill have to get my dad to have a look as this is the first time ive looked into rebuilding a box! |
21st May, 2013 at 08:37:32pm
If you've got the pre '84 (I think it is) Haynes manual that's got lots of info on gearbox rebuilds. Edited by matty on 21st May, 2013. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st May, 2013 at 10:15:55pm
The engine builder DVD was quite good, and for remote style box the minimania YouTube, they both give you and idea, but then I didn't think were perfect, I,e the lack of a torque wrench in the minimainia... But at least you can see how they go together etc. I run a supercharger and I don't care the TB is on the wrong side.
22nd May, 2013 at 08:24:37am
i did mine for the first time and after i did it i thought what the heck was i so worried about?
22nd May, 2013 at 12:28:51pm
whats really confusing me is where 4th gear is etc..
22nd May, 2013 at 02:06:46pm
4th gear is just the 1st motion shaft locked to the 3rd motion shaft.
23rd May, 2013 at 06:41:51am
okay thanks for that, is the rebuild bearing kit okay?
23rd May, 2013 at 08:50:32pm
okay guys been taking mine apart tonight,taken the first motion bearing circlip off, now i need to get the first motion bearing itself out with the gears, how do i do this? from my haynes manual it simply said take it out.. but seeing as its press fit i need something to get it out?
23rd May, 2013 at 08:56:51pm
You can tap the 3rd motion shaft from the pinion end using a soft drift, and that pushes the 1st motion out. The Bering is not that tight, only a light interference fit. Be careful that the synchro for 1st doesn't slide of its hub though. No big deal if it does, but there is 3 detend bearings in there that will ping out. If your worried just put some cling film over the top of the box to stop anything coming out. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
23rd May, 2013 at 09:01:49pm
will give this a go:) thanks matty,
