Home > Help Needed / General Tech Chat > BINI starting problems
mayoturbo
Member #: 1395
chepstow
Intermittent starting on an 05 mini cooper. Thought the starter was duff so changed that but still the same. Lights come on the dash with ignition but wont start, no clicking, sign of life from the starter or anything. After a few attempts it work, Any ideas?
thanks
Edited by mayoturbo on 22nd May, 2013.
Dodgy relay?
mcalvert39
Member #: 442
Manchester
Battery or earth problem?
Mat
Member #: 9939
Sussex England
Check the switched voltage to the starter?
On 17th May, 2013 Rick.SPI said:
Big money if your prepared to do it outdoors in the field.
mayoturbo
Member #: 1395
chepstow
Swapped relays over and check the fuses.
The small wire to the solenoid has 12v... until its attached to the solenoid then drops to 0.06v when touched to solenoid. When the wire looses power the bottom corner of the fuse box clicks like a relay
Car unlocks with the fob. Will bump start and also start when the solenoid is bridged.
mayoturbo
Member #: 1395
chepstow
No different with spare key either
Mat
Member #: 9939
Sussex England
Sounds like that clicking could be a loose connection in the fuse box, what are you measuring the voltage with? Digital multimeters don't apply any load so don't show up bad connections, loose earths etc.
mayoturbo
Member #: 1395
chepstow
Digital Multimeter. I'll have to wiggle the wires in the fusebox and see if anything happens
