Home > General Chat > This any use as a running in oil....
APS
Member #: 10369
Pickering, North Yorkshire
http://www.eurocarparts.com/ecp/p/car-acce...70872&0&cc5_251
Could this do as a 'running in oil'?
Seems pretty cheap for a known brand oil, and I only need it for a short while. The engine isn't 'new', but its had the head off, and the block front/back sanded and it doesn't matter how much you try and cover it up and mask bits, its going to have dust and shite in it.
www.apsbikes.co.uk
That's only a litre.
If you're actually running in, you're better off with cheap mineral. For what you propose, an oil and filter change with CTV would be better.
APS
Member #: 10369
Yeah I appreciated it was only a litre, but 5l would be only 19 quid delivered, so it looked fairly tempting.
So you think the CTV and a new filter would be better? Bugger. Lol.
www.apsbikes.co.uk
sounds like your wanting to clean out as opposed to run in
you could use the supermarket stuff; change the oil; run it up to temp to 'clean' out and then change again?
Asda 20/50 is like 6 quid for 4l. Get a few for a flush. Then back to the good stuff
APS
Member #: 10369
Yeah exactly that Rob. It will be full of shit and just needs clearing out.
Awesome, I'll stick with cheap stuff then, will save me a few quid :)
www.apsbikes.co.uk
