| Home > Help Needed / General Tech Chat > Windscreen refitting | |||||||
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
28th May, 2013 at 08:14:05pm
Hi Guys,
524 Posts Member #: 1380 Post Whore Swindon |
28th May, 2013 at 08:18:41pm
you'll need patience. and obviously the tool for the chrome trim.
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
28th May, 2013 at 08:19:19pm
I've always used a bit of wire and a second pairs of hands method. Never failed. On 19th Jan, 2010 wil_h said:
28th May, 2013 at 08:23:50pm
i have dont the front screen a few times, rubber on the car, fit the glass into the bottom first and lay it back working up the side gently easing the rubber over
Yes i moved to the darkside |
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
28th May, 2013 at 08:29:54pm
I've had no prob at all with this method:
28th May, 2013 at 08:31:58pm
Thank you. As i thought but just needed some reassurance.
28th May, 2013 at 08:34:59pm
On 28th May, 2013 1275min said:
Thank you. As i thought but just needed some reassurance. Ive got the chrome insert tool. if you have the chrome strip i recommend soaking it in a bucket of hot ( but not boiling) water to soften it up, makes life sooo easy Yes i moved to the darkside |
28th May, 2013 at 09:15:37pm
I am working tomorrow night or I could of give you a hand mate, I have used a cake icing thing (I stole of the wife) before as it don't mark if you slip. Also I do it like Brett has said. I have started posting on Instagram also my name on there is turbomk1golf
