Home > General Chat > Servo vac pipe
mini118118
Member #: 10069
Chaps just wanted your opinions please..
If you are using a turbo manifold and servo, do I need to use a one way valve
Currently using just the standard mini 1000 vac/manifold banjo with no internal one way valve.
Will i lose boost or damge the servo, as surely this only wants to see a vacuum.....
You need the one way valve as your servo will see positive pressure and potentially fuel without one.
