Home > Technical Chat > Double roller bearing retainer for 2.95FD
alaskanow0
Member #: 8466
Mansfield
Just rebuilding my new gearbox, however the 2.95 Pinion, is very very close, to the retainer. I've tried 3 different ones and they are all the same. It's a late A+ gearbox.
Is this normal. I'm think of having it machined up to give slightly more Clearence. I have another built gearbox with a 2.95FD, and it's the same.
My 2.76FD had a different retainer.
You need to machine it mat, give it around 1.5 to 2mm clearance. Around the circumference. Of the pinion
alaskanow0
Member #: 8466
Mansfield
Thanks Steve. So do 2.95's have different retainers from factory.
Yes they do, they are not as common as the rest of the pinion sizes
alaskanow0
Member #: 8466
Mansfield
Problem solved, 5mins with the Die grinder and it looks spot on. Good 1mm Clearence now.
Edited by alaskanow0 on 2nd Jun, 2013.
