Home > Help Needed / General Tech Chat > Another question - Sorry!
Chris-G
Member #: 10229
Stroud
There is a t piece sticking out of the inlet side of my t3. One leg is screwed into it, the other two are like 5mm push fitting. What do these do? Can i blank them?
Cheers!
One side goes to the actuator. The other side should be blocked, or you can connect a bleed valve or similar if you want/need.
Phil.
Chris-G
Member #: 10229
Stroud
Thank you for your reply. Is fitting a bleed valve a bad idea then? How else do i adjust my boost pressure without one?
Should the bleed valve not be in line to the actuator so that it affects the signal to the actuator?
you could use one of those for you boost gauge also
You can bleed it straight off one side of the T-piece on a single line to the bleed valve & it works fine. This is how mines been since I built mine in about 1998. *smiley*
Not a bad idea, you just need to be sensible with it. You can add more preload to the actuator or add a stronger actuator to increase boost.
Edited by Turbo Phil on 1st Jun, 2013.
