| Home > Help Needed / General Tech Chat > Brake Help. | |||||||
1st Jun, 2013 at 04:07:28pm
OK bear with me on this one,
Edited by madmk1 on 1st Jun, 2013. I have started posting on Instagram also my name on there is turbomk1golf
1st Jun, 2013 at 06:08:23pm
Id start by flushing the system throught with normal fluid and see what happens.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
1st Jun, 2013 at 06:21:00pm
5l of dot4 from Halfords with a trade card is about 11 quid. On 26th Jan, 2012 Tom Fenton said:
1st Jun, 2013 at 06:24:01pm
whats the line lock? I run a supercharger and I don't care the TB is on the wrong side.
1st Jun, 2013 at 06:35:14pm
Check the pushrod into the master cylinder isnt binding, I had a hell of a job diagnosing the same symptoms years ago with my AP Racing master cylinders (cant remember what you have). I ended up making my own pushrods, iirc Nic Rizz had the same problem and fitted a spacer under his cynders I seriously doubt it! |
1st Jun, 2013 at 07:58:56pm
whats the bias valve?
1st Jun, 2013 at 10:38:41pm
On 1st Jun, 2013 eden7842 said:
Id start by flushing the system throught with normal fluid and see what happens. Thats the cheapest bit 1st ..I was thinking this Mate, like you said its the cheapest bit lol. On 1st Jun, 2013 gr4h4m said:
whats the line lock? ..Its sort of a Hydraulic handbrake On 1st Jun, 2013 paul wiginton said:
Check the pushrod into the master cylinder isnt binding, my AP Racing master cylinders, I ended up making my own pushrods, iirc Nic Rizz had the same problem and fitted a spacer under his cynders ..Before I fitted them I checked then for that, as I made mine aswell, also I have wilwood style. On 1st Jun, 2013 Joe C said:
whats the bias valve? I bough a flash one fitted it and after pressing it down hard if failed leaving the rear brakes locked on solid (fortunatly on the drive!)... binned it and fitted a converted mini one. also I seem to remember early rear Kad discs can do somthing funky where the hand brake can go over centre if theres too much slack and stick on. I sold my Kad rear discs because they were sticky and would bind. Its just to stop the back wheels locking up lol. Yes they are an early set if i don't think i have ever had them working right, come to think of it. So I am not sure boys as its on all of the wheels
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
2nd Jun, 2013 at 07:27:25am
Look at the AP Racing site for all the reasons NOT to use silicone fluid! Among other things it can swell the seals which can prevent the piston from returning. Ask me how I know :( Change all the seals and use proper brake fluid Geoff |
2nd Jun, 2013 at 10:41:14am
I cant find the info you are chatting about mate.
Edited by madmk1 on 2nd Jun, 2013. I have started posting on Instagram also my name on there is turbomk1golf
2nd Jun, 2013 at 12:05:33pm
Just get loads of dot4 and flush id have thought. It's good enough to strip paint so it should be good enough to flush the system through haha.
976 Posts Member #: 3228 Post Whore North of the Netherlands |
2nd Jun, 2013 at 12:10:11pm
Not familiar with silicone brake fluid and effect on seals. But I think I would loosen the T for rear brakes and see if that improves things (at the rear). If it doesn't look at the brakes, if it does improve things continue looking at thing towards the front. Dazed and Confused.... |
2nd Jun, 2013 at 12:43:06pm
Hi carl I have a card thanks, I just flush it with 4L first lol.
11th Jul, 2013 at 06:44:44pm
On 2nd Jun, 2013 h4887 said:
Change all the seals and use proper brake fluid Well I knew this would come back to hunt me. Looks like the 4 little bridge seals on my minisport Calipers are Fucked :( Just one more thing on the list to do. Simon. I have started posting on Instagram also my name on there is turbomk1golf
