Home > Help Needed / General Tech Chat > 286 turbo?
saskinsturbo
Member #: 121
ive got a kent 286 in the shed wot wud happen if i was to put the 286 cam into my turbo wud it go well or wud it mess it up the engine is comin out 2moro for a clean and few extras and was wonderin if it was worth the hassle of puttin it in or not
cheers
saskinsturbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
you'll probably get poor running, low boost and less power than a 266
alex
AlexF
saskinsturbo
Member #: 121
oh yeah my fly wheel and pressure plate keep comin loose any one else experienced this problem?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Is it a verto setup?
AlexF
saskinsturbo
Member #: 121
yeah its a newer type clutch i changed all the assemblie so i cud use the later type starter motor
saskinsturbo
1310turbo
Member #: 41
i have used the later type pre engaged starter with pre verto clutch assembly, just get the different ring gear welded on, mini spares do them quite cheap
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
jukka
Member #: 60
Forgotten more than most ever know
I did check the timing of my first turbo cam (from VMax Racing). The cam is worn to excess but there were one intake and exhaust lobe that were in pretty good shape. Anyway, the timing figures were so close to MD286 that it surprised me a lot. The cam was excellent in 1380 turbo engine. Avonbar Phase 2 was a disappointment after the VMax cam. The next cam that I will fit will be SW10 from Swiftune. I have already fitted one of those in a mate?s engine but he did not get the engine properly set up last summer (due to chasing women... some priorities). So I cannot tell how it really runs.
Jukka
1310turbo
Member #: 41
do you think that the vmax cam is alot better than the avon/piper phase 2 jukka?
ive got that cam in mine yet but from today the engine is being run in so i wont know what its like for a while, i want to put on the vmax head so i suppose the vmax cam would be the way to go, unless the swiftune proves alot better
SumpNut
Member #: 28
I ahve an interesteing looking cam, i was running it in my otherwise standard turbo engine unitl she blew, the new engien has med's cam, but its such a different engine i cant compare, o and it still doesnt work properly *angry*
jukka
Member #: 60
Hard to say, at least Avonbar timing figures are milder than VMax cam. Having said that, turbos tend to run better with milder (also special) grinds so if you need nice road manners do not get too excited with the cam.
My first spec engine gave 133 hp with VMAX cam @ 0,5 bar. I then had to replace the camtrain plus the head due to unleaded fuel causing "slight wear" and bought Avonbar Phase 2 cam. (Mr. Hargrieves charged me over ?60 for shipping 2 cams over to Finland. Needless to say we don?t do business anymore...) Anyway, the engine gave the same 133 hp but now with 0,7 bar boost. The heads are both my own doings, first head had 32 mm ex valves and the later 31 mm valves, both offset etc. so they are more or less the same.
My gut feeling is that the VMax cam was better in power whereas Phase 2 may be a bit better low down. Note that the engine is 1380 which has good low end torque to begin with. It is also very tolerant to cam timing and does to mind the "wilder" cam. 1275 may be totally another issue.
Jukka
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
As you say 1380s can always take a wilder cam and remain nicer to drive... try a 286 in a 998 for poor driveabliity!!! lol
What we need is some back to back testing!
Jim... hurry up an buy a dyno!
alex
AlexF
