Home > Help Needed / General Tech Chat > Powdercoating fuel tank
jamestar
Member #: 9159
Devon
Hi guys, probably an easy question but I just want to make sure, would it be ok to powdercoat my alloy fuel tank? the only thing that worries me is that it's foam filled and I'm not sure if it will be able to handle the curing temperatures, it hasn't been used so not a drop of petrol has been in it.
Thanks in advance, James.
I'm guessing the sponge would probably burn/wilt :/
I guess you could fill it with water but you'd need to leave it for a long time to air dry out, or flush it through thoroughly with fuel?
Take the foam out
Take the foam out and have it anodised ( not the foam obviously, the tank lol )
Or was the tank constructed with no means of future access ?
jamestar
Member #: 9159
Devon
Anodising sounds like a good idea!
The only way of take out the foam is through the filler cap or fuel sender, if that's even possible?
How do you think they got it in there???
APS
Member #: 10369
Pickering, North Yorkshire
Take it to a body shop and have it painted?
www.apsbikes.co.uk
They insert the foam before welding it shut.
At least that's how my tank was made years ago.
And obviously cheapest and quickest way for them to do it.
A friend recently got his new tank anodised black....and have to say, it does look superb.
If the tank is scraped or marked, or corroded...ie old, obviously any anodising finish wont be as nice though. If it's brand new, you'll be good to go.
Not sure how feasible it would be to anodise with the foam inside though. Although I guess if all apertures were sealed so none of the acid could get inside, you should be fine.
I had my friends tank deliberately made with an access plate on top so we could remove the foam and gain access inside if needed.
Edited by stevieturbo on 15th Jun, 2013.
The foam should not be just one piece. It is usually inserted in 2 or more sections after welding.
If you insert it before it will burn and make gases which will make the welding porous.
Its quite amazing how large a piece of foam you can insert through a filler neck
Edited by paul wiginton on 15th Jun, 2013.
jamestar
Member #: 9159
Devon
Cheers chaps, I'll have a lookalike taking out the foam and enquire about getting it anodised.
My tank is a large rectangle, and the only opening a 2" hole at one end for the filler neck to bolt on. There is a small opening on the top for the VDO sender. This extends down into the foam, so the foam is cut to perfection larger diameter than the VDO sender itself. It's a perfectly round hole however they cut it.
I really cant see any way they could have done mine without welding it shut with the foam inside. Maybe when welding they purge the inside with argon too.
My friends tank was made elsewhere, as I said we got an access plate fitted to the top. That guy just seemed to stuff whatever bits of foam he had lying about into the tank. Lots of small pieces, but bigger than the access hole itself.
Edited by stevieturbo on 23rd Jun, 2013.
Its surprising how small this foam goes. I have squeezed two 12"x12"x24" pieces through a 1 3/4" filler neck on a tank Ive made.
You cannot stop the foam from burning even if you do purge it with argon gas
You have to think that the foam needs to be able to only just stop fuel sloshing about and just have the minimum amount of displacement so as it doesn't just absorb it like a normal car sponge. Therefore it will squeeze down much smaller than normal sponges.
