Home > Help Needed / General Tech Chat > Low oil pressure cut-out
Cables69
Member #: 10196
Hi me and a mate are thinking of wiring in a low oil pressure cut out switch in our cars to prevent serious damage should the oil pressure drop dangerously low. I've heard people plumbing in a SD1 sensor and using it to cut the fuel pump (but we are probably going to cut the power to the coil as mine would run ages with the fuel in the weber) but has anybody else out there used anything different?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i whouldent do in a sreet car image pulling out onto the free way and she cuts out you look to see a car truck what ever o crap..
on a track car sure just have the coil power pass throw a relay witch is held in by the oil pressure light oil presure drops the relay lets go and the coil is dead till oil presure is gained you also need a momentary push button or 5 second timer to alow starting the car just a 12v to the relay hold in termal just see if the oil switch is open or closed under normal pressure and also see if it operates at what you deam to be unsafe for the motor i can do a wireing diagram if you like
Cables69
Member #: 10196
mine is a track car, so i'm ok with that, they are installed in alot of road cars (the afformentioned SD1), my mate just doesnt want the incident the other weekend when his gf nearly killed his car
oli79
Member #: 8480
Fit a massive fuck off oil warning light on a higher rated/adjustable sender to give advanced warning?
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Cables69
Member #: 10196
lol that didnt work for her, drove it 20miles with no water cause either the plastic plug on the thermostat housing had come loose, or more likely some thieving barstuard had taken it at the show they were at, when it got home the oil sounded like a deep fat fryer
