Home > Introduce Yourself > HEY!
jordan1330turbo
Member #: 10459
Hi I am not new to turbo minis but I am new member I have had my mini for 2 years and love it has had a new 1330 which i have built with my uncle who is a skilled engineer but after a start up today after a few months of sitting to check tappets,oil,water ect i have heard a bad knocking noise from around the speedo drive area and have posted a video on youtube.
Someone please shed some light on this mysterious noise as the engine has been run in for a few months and have never heard it before.
https://www.youtube.com/watch?v=wRJxM2wPtx4&feature=youtu.be
Thanks! Jordan :)
WRLondon
Member #: 8636
Surrey
have you got a single or duplux timing chain?
Reading up on RTS Clutches
jordan1330turbo
Member #: 10459
Duplex your on my wave length :/
WRLondon
Member #: 8636
Surrey
did you modify the timing chain cover enough?
happened to mine where i cut and bent back the bit that sticks out
a piece broke off *doh*
same thing can happen to the locking tab
need to take out the rad and get the timing chain cover off and have a look
jordan1330turbo
Member #: 10459
The rad is a F***er to get out :).
When i bought it i asked w and p and they said it will be fine :/ thanks though bud :)
jordan1330turbo
Member #: 10459
Did you watch the video its clear sounding may help you work it out ??
there are 2 bolts that go through the front plate into the main bearing these need to be counter sunk and swapped for some counter sunk head type bolts
and the timing chain cover has to be modified, there is a 3/4 circle in there that would normal surround the oil thrower that needs to be cut out,
its not clear from the sound witch one is causing the problem but i will half guess the timing chain is catching the bolt heads
jordan1330turbo
Member #: 10459
The bolts are flush we did that but no modifications to the casing :/ thanks
lee.pb
Member #: 9199
Lancashire
did you knock the lump out of the cover as the chain catches on it.
Firstly. A warm welcome! As the lads say above,
Your uncle needs to learn a few more skills I think.
Get it sorted before it all ends in tears
jordan1330turbo
Member #: 10459
Benross I done that bit :p but would of done more if wood and pickett warned me oh well live and learn. Cant wait to struggle at the weekend :)
jordan1330turbo
Member #: 10459
Sorry lee just read your comment lump ?? Im trying to picture it but il have to have a proper look at the weekend
Ahh yeah... welcome to TM aswell :)
lee.pb
Member #: 9199
Lancashire
there's a small lump "circled in red" that needs knocking out as per the attachment.
this is what the internal of the cover should look like, i made the same mistake and the chain rubbed through in the end.
You DO NOT need to remove the metal retainer type bit in the top of Lee's picture.
Eyup BTW.
lee.pb
Member #: 9199
Lancashire
thought the ring had to be removed to allow clearance for the duplex chain *oh well*
if not why the "duck" have i gone it on two covers now eeeerrrrrrrrr dam mini forum *surprised*
Eyup BTW.
I've never removed it and not had any problems. You just have to bash the dimple out.
lee.pb
Member #: 9199
Lancashire
weight saving then lol
WRLondon
Member #: 8636
Surrey
lol, i took the ring at the top off too :/
either way whip it off and let us know *happy*
dont forget you have to take the starter motor off to lock the flywheel to get the big (30?) nut off
to take off the timing chain covererer
jordan1330turbo
Member #: 10459
Cheers guys will do it asap just hope its that *Shooting*
andy you DO have to remove the ring if its fitted with a rotorslide adjustable duplex,
a standard or lightend steel or cast duplex you you can leave it on
jordan1330turbo
Member #: 10459
Just lightend duplex Benross but I am learning every second with these posts cheers guys also thanks lee that picture really will help :)
lee.pb
Member #: 9199
Lancashire
mines just a ligtend duplex but removed anyway.
my lightend duplex wore a hole in the cover after about 1000 miles as didnt knock out the lump *oh well*
Carolee
Banned User
Member #: 10463
Hello,everyone,nice to meet you here.
GROAN. Bye.
