Home > Help Needed / General Tech Chat > Cable clutch
diddy
Member #: 505
Stockton-on-Tees
this may have been asked before, but my search found nothing.
My engine had a cable operated clutch fitted to it. obviously i want to change it to a hydraulic one. I can get the bracket, slave cylinder and plunger off one of my 998 engines to attach onto the clutch housing.
Is this the correct way to do it tho?
There was a considerable difference between the angle of the clutch arm i took off, and the angle of a 998 clutch arm. Will i still get the required amount of movement to change gear?
just need to use the correct hydraulic arrangement for which clutch your using.
i.e. std turbo - verto
most upgrage/lightened stuff non-verto setup
Yep, as Iain says, all you need is the hydraulic parts from an appropriate engine.
As the Metro was verto then you'll need a verto slave cylinder and bracket and the endcover with the short arm and correct release bearing.
Wil
diddy
Member #: 505
Stockton-on-Tees
Cheers guys,
I've got the parts so I'll get it put together then!
