Home > General Chat > Pic request
flyingturd
Member #: 4008
near cardiff np12
looking for ideas on intercooler pipe set up
what intercooler your using and size
i have a clubman so have a bit more room than a roundnose but if im to turn one i want some ideas and best setups thanks
alaskanow0
Member #: 8466
Mansfield
RS turbo Series 2 intercooler fits nicely in one section of the grill area. Ok up to 150bhp. Pick one up for £15.
flyingturd
Member #: 4008
near cardiff np12
what about this
http://www.ebay.co.uk/itm/ESCORT-MK3-RS-TU...=item3ccdf88d5c
Search 'intercooler' and 'engine bay' there's lots of threads showing differents setups.
wolfie1
Member #: 9575
Nr a shithole (Wolverhampton)
Got a Pace alloy uprated 5GT Turbo 1 of fleabay for a tenner. Rather than going to Fleabay direct use Fatfingers cos that will allow you to abuse the fact a lot of peepel karnt spel
Cosworth intercooler would sit well, however have search as the oneeye has suggested. Plenty of threads on the subject
I have a cossie 4wd cooler to sit behind my grille for when the time comes.
welshdan
Member #: 1111
s wales
The cossie 4wd one is a beast of an intercooler, i plan to fit one to mine next. I have an rs turbo one in the for sqle section. Cheers, dan
T3Tone
Member #: 252
Sunny suffolk
Got a 4wd cossie intercooler in a clubman, fits nicely behind the grill with enough room for air filter to live beside it.
-MINI CLUBMAN 1380 TURBO-
this is a great choice IMO*smiley* ...... my next venture will impliment one, *Yes*
there are some good intercoolers out there, just fit one that is proven from past members experiences,
like matt has mentioned ............ But if you have the room then go for a larger one if you can get ample airflow through it to cool the charge better!!!
flyingturd
Member #: 4008
near cardiff np12
Cheers ill look for a 4wd cossie one
