Home > Beginners Tech > floor cover
Rammie2000
Member #: 10190
belgium
Hi all now the welding is done on the car i am looking for something ho cover te inside floor. I got rid of all that hard stuf inside but cannot live with the vieuw of the welding seems. Question is what could i cover it with. Do i look for the same black stuf that was on there? Or are there ready made teardrop flootplates to put on the front? Or dynamath...
Grts
You could use dynamat or equivalent. Flashing tape is a good cheap alternative too.
dynamat is heavy, some tool plastered the skyline with it, its awful stuff to work with, around, near
still the audio system is top notch *happy*
I have anti slip home made matts in the metro, there is no sound deadaning or carpets it works a treat and doesnt look to bad *smiley* got it from asda or tesco iirc only cost about $5
Rammie2000
Member #: 10190
belgium
Looked at dynamat but indeed bit heavy. I tought about aluminium teardrop plate to make it myself but then again... it wil be as heavy as dynamat.
What about epoxy. .. tought about that to (no sound deaning but so be it)
vegar
Member #: 189
How about just the carpet for the floor, not all the small bits
www.shag.no
You could buy just some floor mats?
stone chip
Rammie2000
Member #: 10190
belgium
Njeee.. i hate carpet. .. if it is not stuck down it shifts if it is stuck down it traps moisture. .. stone chip... tought about it but it gets soft and sticky when hot... i would like it nice and tight.
WRLondon
Member #: 8636
Surrey
You can get different thicknesses of dynamat but as you say Brett only really good for SPL level sound installs
Used to do it for alpine show builds etc. when I was a teenager lol!
The mpi moulded carpet is good and easy to work with as it's one piece
Or could go for the racer style metal chequer plate look
Orr just floor mats if the paint is looking
Good
But a pain to keep clean if it's a daily driver
Done all the above haha
Reading up on RTS Clutches
You could make some anchor points for the mats as per most modern cars to stop them moving around.
Rammie2000
Member #: 10190
belgium
there is an idea... that i didnt thinck about that. would the original systems still be for sale? hmm may have a look tommorow in the local shop.
WRLondon
Member #: 8636
Surrey
Thats a good idea
They usually made by moulding onto the original carpet
But sikkaflex sticks like a fly on poop!
(don't get it on your hands though !)
Rammie2000
Member #: 10190
belgium
Thats a good idea
But than i can't remove them anymore to let the moisture out. I think the oldschool option will be the way to go. Find something nice and tidy to do the complete floor and what is left of the back seat.
That or epoxy coating. (Keeps sticking in my mind to because it can be painted)
Edited by Rammie2000 on 15th Jun, 2013.
Actually I've just thought, if you buy the right mat, it won't move anyway, mine fits around the steering column so it can't slide forwards. I'll try and get a picture later.
Rammie2000
Member #: 10190
belgium
Now what you mean. Have one like that in paulintje (my 42 year old mini) but it still has the strange rivets to hold it down (never checked if it would stay in place without it) dont want to heavy mats though (paulintje s carpets are like they are made out of lead thinck its the original carpet)
APS
Member #: 10369
Pickering, North Yorkshire
How about black press studs in the corners? It will allow you to take them out to clean then, and gives you chance to check if its dry etc.
www.apsbikes.co.uk
Rammie2000
Member #: 10190
belgium
That is probably what I will be doing.
Grts
m1100s
Member #: 9777
Adelaide, South Australia
Mini Sport do a Carbon Fibre floor tray that just sits on top & goes all the way to the top of the crossmember.
I have a Mini again & a collection of Turbo bits, what to do???
WRLondon
Member #: 8636
Surrey
Grts
i was suggesting a way to fit the press studs not the entire carpet *happy*
Rammie2000
Member #: 10190
belgium
Grts
*surprised*
APS
Member #: 10369
Ive only just seen this!!! Philistine *happy*
www.apsbikes.co.uk
