Home > Help Needed / General Tech Chat > turbo engine won't run on boost
tomostrash
Member #: 10334
Staffordshire
I have a running problem only on boost if I disconnect the turbo outlet pipe it runs ok I'm sure its to do with the carburettor ballance pipe but it won't run correctly when its connected.Regards tomostrash
Edited by AlexB on 13th Jun, 2013.
tomostrash
Member #: 10334
Staffordshire
It was the plenum gasket as it was missing the hole to the carb
