Home > Help Needed / General Tech Chat > new complete rebuilt metro turbo engine won't run on boost
tomostrash
Member #: 10334
Staffordshire
Hi guys i have a problem only on boost as it cuts out if I disconnect the turbo outlet pipe it runs ok I'm sure its to do with the carburettor ballance pipe but it won't run when its connected. Regards tomostrash
eden7842
Member #: 8852
leicestershire
Search the t-peice trick easy thing to try for a start.
Also whats your fuel pressure set too?
WRLondon
Member #: 8636
Surrey
Sorted!
Plenum gaskets can be abit tricky
Reading up on RTS Clutches
