| Home > Help Needed / General Tech Chat > K1 head conversion running off BMW ecu? | |||||||
160 Posts Member #: 1085 Advanced Member Netherlands |
14th Jun, 2013 at 07:43:20pm
Hi all,
1963 Cooper
14th Jun, 2013 at 08:18:20pm
Well if im not mistaken the standard bmw engine revs alot higher and most surely will require a different ignition and fueling setup deeming it fairly unsuitable, I have a k100 head ecu and injectors and I wouldn't even consider using it, if you want a reliable and safe setup for the car with good drive ability get a stand alone ecu like megasquirt, emerald, omex ect Drives
14th Jun, 2013 at 10:35:48pm
Its been done, so yes, it is possible, but I think it was a chipped ECU though. That was the K1200RS though. Edited by Sprocket on 14th Jun, 2013. On 26th Oct, 2004 TurboDave16v said:
![]() 720 Posts Member #: 2588 Post Whore Pretoria South Africa |
15th Jun, 2013 at 07:29:17am
Im sure Ive seen a vid of madmat running a twinky on the ground with no exhaust, at one point he points out that its running on the original beemer ecu. it was a long time ago though. "So wat we gonna do tonight Brain?"
15th Jun, 2013 at 10:30:36am
you'll be able to get it to run, but it'll not be optimum. On 28th Aug, 2011 Kean said:
15th Jun, 2013 at 07:22:53pm
thanks guys:) 1963 Cooper
