Home > Help Needed / General Tech Chat > panic over....
1310turbo
Member #: 41
yes the panic is over, and yes i will be eating a lot of humble pie...it was 180 degrees out *blush* *blush* *blush* *blush*
thought i would check it again and going through the cycle i noticed it was out, so its all fixed now! cheers dave for the offer of coming down to have a look at it, good job you didnt drive all the way down here *blush* *blush*
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
180 degrees out...
Enough said. *laughing* *laughing* *laughing* *laughing* *laughing* *laughing*
