| Home > Help Needed / General Tech Chat > Starting problems, sounding like a tractor, | |||||||
62 Posts Member #: 10154 Advanced Member Taunton, somerset |
17th Jun, 2013 at 08:48:41am
17th Jun, 2013 at 08:51:15am
compression test.
17th Jun, 2013 at 09:00:01am
Sounds like the exhaust has fallen off at the elbow. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Jun, 2013 at 09:01:03am
Has your trigger wheel for megajolt moved?
17th Jun, 2013 at 09:04:28am
Check you ignition leads firing order
17th Jun, 2013 at 09:18:08am
fast replies as usual so thanks
17th Jun, 2013 at 09:20:11am
Coil pack could have failed (unlikely but possible) If something is worth doing, it's worth doing half of. |
17th Jun, 2013 at 09:29:37am
as benross says it will still run but badl with miss matched leads |
17th Jun, 2013 at 09:48:13am
Will double check the firing order tonight. and make sure the coil pack is okay |
17th Jun, 2013 at 10:23:52am
As it's MS and a coil pack, your leads will either be right or wrong.
1170 Posts Member #: 8636 Post Whore Surrey |
17th Jun, 2013 at 01:30:54pm
as above
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
28 Posts Member #: 9094 Member near hull |
17th Jun, 2013 at 02:06:25pm
i had this problem on my n/a 1380 found it to be a failed head gasket between cyinders 2 and 3 |
18th Jun, 2013 at 04:41:10pm
Didnt manage to check compression last night. just checked now theses are the results
18th Jun, 2013 at 04:47:53pm
Looks that way. On 11th Feb, 2015 robert said:
18th Jun, 2013 at 04:55:40pm
head gasket has gone and guessing by the figures its gone took the kids and emptied your visa at the same time Yes i moved to the darkside |
18th Jun, 2013 at 05:00:39pm
Thanks for the clarification. Anything else worth changing at same time? |
18th Jun, 2013 at 05:13:07pm
while the head is of i would stick an injection exhaust manifold gasket on there, the ones with the fire rings on the exhaust ports, Yes i moved to the darkside |
18th Jun, 2013 at 05:31:23pm
Thanks will replace that aswell.
18th Jun, 2013 at 05:59:27pm
What you need to think about is why it went.
25th Jun, 2013 at 10:54:32am
So got the Head gasket all changed at the weekend.
25th Jun, 2013 at 11:00:03am
White smoke (or very very light blue ) can also be oil straight into the exhaust how's the turbo?
25th Jun, 2013 at 11:07:06am
Turbo seemed in really good condition no play or anything. No smoke when driving on boost. What's the best way to check if it this, would the seal go both sides. I can't see any oil in the inlet side of the turbo. |
26th Jun, 2013 at 06:21:53pm
Just had the rocker cover off and there is some white stuff in there, would this be any thing to do with the white smoke?
32 Posts Member #: 2150 Member |
26th Jun, 2013 at 07:45:09pm
If you didn't change the oil when you did the head gasket, the white smokes the water burning off thats in the oil.
26th Jun, 2013 at 08:22:16pm
Will drain the oil and give that ago thanks for the help. Will update |
