| Home > Help Needed / General Tech Chat > New Engine Build. | |||||||
![]() 171 Posts Member #: 9928 Advanced Member Hartley, Kent |
17th Jun, 2013 at 02:46:43pm
After running a lash up turbo setup for a while and gathering much knowledge whilst enjoying turbo'd A series I feel a time has come to slowly build a PROPER engine much better suited to the requirements, as and when my funds allow me.
Low boosting for now. |
614 Posts Member #: 2153 Post Whore kings langley |
17th Jun, 2013 at 02:51:09pm
Well you need to get the bores measured to see if they are still round and straight if not you can always get it linered back down to any size you want... Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
17th Jun, 2013 at 05:01:25pm
Roger wilco. But will a 1380 turbo be reliable? Thats my main concern.
17th Jun, 2013 at 05:42:08pm
I always have my engines machined to the actual pistons that im using. A lot of places will be reluctant to bore and finish a block without the actual pistons to be used to hand. I run a 1380 turbo, its been reliable so far but not got too many miles on it yet. You may struggle to get the compression ratio down with the current off the shelf 1380 pistons available... |
17th Jun, 2013 at 06:20:23pm
i think madmk1 is 1380 turbo and benross aswell, Yes i moved to the darkside |
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
17th Jun, 2013 at 07:19:05pm
No reason why any engine size would be unreliable if its set up correct, comp ratios fueling ignition etc etc |
17th Jun, 2013 at 08:23:38pm
i have a 1380 turbo running very high boost with no issues whatsoever! 5000 hard miles on it over many years,
17th Jun, 2013 at 10:42:42pm
I use 73.5 18cc accralites. I dont think that either these or omega ones are kept on the shelf, but manufactured in batches. Best to speaK to omega direct... |
18th Jun, 2013 at 02:46:18pm
I see omega 73.5 cast are only 11cc's from MED at the moment, i think 11cc will be alright if i chamber the head out enough.
