Home > Help Needed / General Tech Chat > Somethings Up!
turbo55
Member #: 10483
I have recently built a metro turbo engine and installed into my mini, i managed to get it running fine,
didn't touch it for a week and now it is not starting, i checked the following,
fuel pressure
fuel getting through
mixture is same as before
timing was set up whilst it was running, hasn't changed
there is a spark but it only seems to spark when it is not actually touching a point to earth. (found this very strange)
checked the float level, jet and made sure there are no blocks
any recommendations as i have spent the day trying to rectify to success, Very Frustrating
thanks
dev 11
Member #: 9393
stoke on trent
Battery? Sounds silly but just might not have enoufh cranking amp start
Edited by dev 11 on 19th Jun, 2013.
turbo55
Member #: 10483
thanks for the reply, the starter motor is a bit tired, but i have one of those battery chargers with an engine start mode, fastest i've ever heard a mini turnover lol
turbo55
Member #: 10483
anyone in the Bournemouth area fancy taking a look
wng691s clubby
Member #: 9252
Cleethorpes
worth checking earth leads, battery lead for shorting ect it will be something simple
Edited by wng691s clubby on 19th Jun, 2013.
Done now needs redoing lol
turbo55
Member #: 10483
yea thought about the earths, have got two big earths attached to the engine.
wng691s clubby
Member #: 9252
Cleethorpes
have you checked dashpot oil level? i have to top mine up all the time and its pain to start if its empty
mcalvert39
Member #: 442
Manchester
Are you running points? Poss condenser?
adrian
Member #: 2726
wakefield
Welcome to the forum mate :)
turbo55
Member #: 10483
got the metro turbo dizzy
turbo55
Member #: 10483
Thanks
turbo55
Member #: 10483
i will check again tomorrow, did look like it was lubed ok though
Are the spark plugs clean or coked up to hell? Is there a loose HT lead? (had that before, they were all pushed in but the centre one wasnt contacting properly and it wouldnt start even though it looked to be sparking okay)
Edited by Carlzilla on 19th Jun, 2013.
WRLondon
Member #: 8636
Surrey
Engine earth strap?
All hoses for the carb sealed and air-tight?
(both of those got me at first lol)
Reading up on RTS Clutches
T3Tone
Member #: 252
Sunny suffolk
What was the timing set at?
If it was set while it was running and now wont restart I was wondering if theres too much ignition advance while cranking to get it started.
-MINI CLUBMAN 1380 TURBO-
turbo55
Member #: 10483
hi, timing was set at 8 degrees have tried adjusting it
turbo55
Member #: 10483
have looked them over seem ok, was fine before too
On 19th Jun, 2013 WRLondon said:
Engine earth strap?
turbo55
Member #: 10483
sparkplugs are pretty black, have front mounted radiator so will pull out to check the leads.
what plugs are recomended if i go and get some more ?
Give the plugs a good wire brush up, bp6es i think are fine, maybe 7's but someone who knows more than me will either confirm this or tell me im talking shit lol. Bp6es is the standard n/a plug and I believe the bpr6es was the standard metro turbo plug.
turbo55
Member #: 10483
Eventually got it started after many hours of sole destroying diagnosis.
did many of the suggested, but i believe it turned out to be a faulting ignition module, as after removal and refitting, i got it started, I will order a new one as a replacement. always the last thing you try
Thanks for all the help from everyone hope to see you on the road soon.... just need an MOT cert now
*Clapping*
