Home > General Chat > megajolt leads
jamiestevenbell
Member #: 9941
Derby
Hi does anyone know where I could buy some leads to suit a megajolt but with the bent ends onto plugs rather than the straight ends or is there a kit you can buy to change the ends? Cheers
You can buy new spark plug sockets, i got my last lot from ebay
james962
Member #: 3663
Banbury
These are what I have used:
http://www.eurocarparts.com/ecp/c/Ford_Ka_...48a7d7be&000198
lee.pb
Member #: 9199
Lancashire
i bought the coilpack end soff trigger wheels and the HT leads and caps off ebay.
then put them together myself
hazpalmer
Member #: 9038
Carlisle, Cumbria
i got mine off oli on here, he said he had them custom made i think.
APS
Member #: 10369
Pickering, North Yorkshire
Not wishing to hijack this thread, but is it easy enough to buy the caps and a roll of lead and make your own?
If so, is there something I need to do/be aware of/buy extra? Etc?
www.apsbikes.co.uk
Yes its pretty easy,
you cut the cable, strip the end to leave a bit of the centre string core poking out, fold it over sthe side of the cable and crimp the connector on.
I've normally just got normal ones and shortened them to fit,
jamiestevenbell
Member #: 9941
Derby
Ok has anyone got a link to a suitable set of leads caps I cannot then
just stick " sparkplug 90 "
in ebay there is many
i have used these in the past
http://www.ebay.co.uk/itm/IGNITION-SPARK-P...=item1c10bff6c6
Edited by Brett on 21st Jun, 2013.
APS
Member #: 10369
Muchos gracious for the info.
Is all HT lead equal, or is there better makes/types etc?
Sorry Jamie if this has taken your thread off your initial subject.
www.apsbikes.co.uk
jamiestevenbell
Member #: 9941
Derby
No offence taken threads is here for everyones benerfit
