Home > Help Needed / General Tech Chat > cylinder head cutter
wng691s clubby
Member #: 9252
Cleethorpes
which cutters/ drill bits do you guys use when enlarging chambers on your heads any lincs would be good*happy*
Done now needs redoing lol
jlay
Member #: 1742
essex
i use carbide cutters mainly as i use there for work also. the ones i use are snap-on but there are cheaper good ones out there. i have also used the cheap stone wheels you can get but they do wear quick. i have made some tools for the finishing which hold emery roll these blend and give the desired finish.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
^^just about summed it up quite well
a carbide burr for removing metal fast
cheap stones for tidying, i bought 50odd from ebay ( they last like 2 mins)
and i also made a tool for holding sand paper in a disc sort of shape ( home made roloc kind of thing)
i would enlarge the chambers using a pair of old valves to protect the valve seats
Edited by Brett on 22nd Jun, 2013.
wng691s clubby
Member #: 9252
Cleethorpes
chears guys i have purchasd a set of snapon burr's from the bay so they should be here nxt week and i can get enlarging
