| Home > Help Needed / General Tech Chat > which brake master cylinders? | |||||||
![]() 233 Posts Member #: 863 Senior Member Lathom, lancs |
20th Jun, 2013 at 09:40:54am
Hi everyone,
Edited by MINIMON on 20th Jun, 2013. |
20th Jun, 2013 at 09:08:05pm
Anyone any advice, need this all done asap so ordering as much as I can for my week off next week. |
24th Jun, 2013 at 11:27:46am
Sorry ive changed my search criteria and discovered the very answer I need! Or so I thought....
90 Posts Member #: 10229 Advanced Member Stroud |
25th Jun, 2013 at 09:40:15pm
I had this very same thought when doing my conversion. I know some people use a 1" AP Racing master cylinder and a 4 way tee piece (2 to the fronts and 1 off to the rear plus 1 input). But im not sure how this affects your MOT because your car was not originally made which a single circuit brake system. Ive since purchased a KAD pedal box which mounts into the engine bay. Its a really nice piece of kit (although i havent yet used it). You can then keep your split circuits to keep mr MOT man happy and also run different master cylinders. I run a .75 front and .625 rear (although not tried and tested). Ive fitted an in car cable adjuster so i can play around with brake balances.
26th Jun, 2013 at 08:30:20am
Ahh really, so 1" master cylinder is good enough? that makes it roughly a .75 front (as recommended) but only .25 rear? Or am I getting that all wrong?
![]() 293 Posts Member #: 10010 Senior Member Northants |
26th Jun, 2013 at 09:51:11am
A 0.75" front and 0.625" have a combined volume of aroung 95% of a single 1" as the volume is proportional to the diameter squared. So you would think that if a 0.75 front and 0.625 rear are alright, then a single 1" would do the job, but i'm not sure and I would wait for someone with experiance to comment. |
26th Jun, 2013 at 12:18:39pm
WOW.... Mind, now f**cked.... hahah.
