Home > Help Needed / General Tech Chat > Fuel pump ballast resistor
paul25
Member #: 596
Hi there,
New to the site and 60% (optimistic!)the way through building 1293cc turbo mini van.
I am doing the wiring at the moment and have read the various ways to wire the fuel pump in. I have decided to use the ERA turbo method (thanks for info!) Question is what level of ballast resistor should I use (if required) and where is the best place to get one?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
no resistor required on the metro turbo pump!
Alex
AlexF
But std metty turbo's used one i believe to make the pumps last longer.
As alex says though, virtually nobody uses them *smiley*
Gibbo
Member #: 34
It's a strange one that, because the pump states that its 12V on it. (So not a ballest pump)
Also why would you need a ballest system on a carb'ed car? There's always enough fuel left in the float chamber to start the car.
I might have a look at my manual next time I'm in the garage and see if I can work it out.
Unless they wanted to slow the pump for some reason???
Anyway like the others said forget it!
paul25
Member #: 596
Cheers Guys,
Will try and post some pics of the build later in the week.
think they did it to prolong pump life as it was more than happy at the lower voltage, or so im lead to believe *happy*
not sure where i got that info from mind!!
turbo hogster
Member #: 178
stowmaket suffolk
yes because the pump could suplly about 60 % more fuel then the engine needed so they fitted a ballast resistor to prelong the life.
but most peeps on here require a lot more fuel than a standard metty so no need to ballst the pump.
