Home > Help Needed / General Tech Chat > Fuel tank outlet
wolfie1
Member #: 9575
Nr a shithole (Wolverhampton)
Just wondering which way people have gone in connecting the fuel pump to the tank. I figure it's the choice of an inline hose reducer or welding a 12mm outlet at the bottom of the tank
i went for the welded outlet this time as i had alot of fuel pressure probs last time
- last time i used the std mini outlet with a reducer and T'ed the return in before pump
but many have used this method with good results
tadge44
Member #: 2500
Buckinghamshire
Don,t you connect the fuel pump to the filter first ? I do.
My tank out let is tapped 14mm OD -about 10mm ID
Yeah my current settup is something like 14mm tank out - 12mm id pre pump filter - 12mm pump input - 8mm post pump filter - fuel feed line - regulator - fuel return line / feed.and return are both 10mm micro bore copper
My fuel system has been good at 43.5 ish psi fuel pressure :)
Edited by Brett on 21st Jun, 2013.
